Is there a way to get disabled VI block diagrams in .exe excutable file?
I have few disabled VI block diagrams in my old executable file, please help us a way to get the disabled block diagrams in .exe file.
Environment LabView : 6i
Ashok
(1,439 Views)
Unfortunately, you cannot decode an EXE to get the VI
Santhosh
Soliton Technologies
(1,430 Views)
The block diagrams in a build executable are NOT disabled. They are simply not there, nada, futschi, gone!
There is NO way to get them back, as they don't exist in the executable.
You will need to find the source code that was used to build that executable.
Rolf Kalbermatter  My Blog
(1,425 Views)
There may be a chance that exe was created with debugging enabled. If this is true, it may contain the diagrams You are after. Check this: https://labviewwiki.org/wiki/Debugging_Executables
(1,398 Views)
While this is technically true, 99.9% of all LabVIEW executables that get distributed for real use by someone else than the programmer, are build with debugging disabled and therefore the diagrams removed. Mostly because that is the default, but also partly because many people build executables to have their diagrams not exposed (be it to protect precious IP or save themselves from embarrassment for the spaghetti diagram 😁 ).
(1,382 Views)
