Is there a way to get a status returned from the Set System Image vi
I am building an application that uses the RT system configuration vi's, and I was wondering if there was a way to get an actual progress status feedback from the set system image vi?
Or some other method of getting actual feedback?  Right now in my application I open a progress bar window but it doesn't mean anything other than telling the user that the system hasn't crashed as it just cycles back and forth.
I know the RTAD has a status feedback, but it is going WAY deeper than needed and there really isn't a simple way that I have found to pull out the "deploy image" stuff requred and drop it in my application.
Eric.
(2,969 Views)
If you want to add a progress bar, there are a couple of example codes for that:
Progress Bar API for LabVIEW
https://decibel.ni.com/content/docs/DOC-17541
Incorporating the Windows 7 Progress Bar Into LabVIEW
https://decibel.ni.com/content/blogs/labview-examples/2011/07/04/incorporating-the-windows-7-progres...
(2,921 Views)
Puchkov, thank you for those links.  However, the progress bar itself really isn't the issue.  I was wondering if there was a way to use the sysconfig library and get a feedback as to the progress of the image deployment that I could use to update the value of the status bar?  Right now I don't have anything to feed to the progress bar.
(2,914 Views)
I browsed through all the functions in the Real Time - RT Utilities - System Configuration, and there were no functions to get a status of each of those APIs. These VIs are password-protected, therefore there's no way to include the functionality of a progress bar.
(2,889 Views)
Yeah, that is what I sort of thought.  Kind of a shame.  Maybe I should put that in as a feature request.
Thanks for your help.
(2,884 Views)
