10-06-2005 09:48 AM
10-06-2005 10:03 AM
It would not suprise me. There are usually artifacts left in released code for features that were dropped. Duel scales on graphs were in a previous version, and when enabled typically caused LV to crash. Delete from block diagram was in a couple of revisions before being formally put into the options, then the switch to enable 'hidden' properties and methods and so on.
BTW, I am not saying that there has not been work arounds for this stuff in the past. I have been doing this for a little while... I am simply trying..although not successfully to say that this can be a more powerful tool than simply a way to comment out code.
Similar to when LV supported text and enum naming in the case structure. That has developed into it's own programming architecture that was available, but much harder to do prior to that addition.
As for open G. Well I wish I had time to support that effort. Heck I am doing good to be keeping up with this thread alone! Only cause I have not been sleeping well, did I even get onto this boards.
10-06-2005 10:14 AM
@becktho wrote:
wow - there's something strange going on.
just wanted to submit a message and out of a sudden there are four...
very strange....
10-06-2005 10:35 AM
Not exactly. The one in 7.x was officially available with the PDA (and I think FPGA, too) module and was like a case structure for platforms - if you were running on windows, only the windows case would be enabled, running on pocketPC - you get the point. According to the documentation, this has only 2 states - enabled and disabled. The principle is the same, though.
@Khalid wrote:
Isn't the one included in 8.0 the same as the "hacked" / undocumented version from 7.x?-Khalid
10-06-2005 10:52 AM
I addition to the Diagram disable structure, we also have the Conditional disable strucuture (Which has been around for a while, but is now directly available in the palette). It lets you define what executes depending on target type (Windows, FPGA, PalmOS, RT, Mac, Unix, and PocketPC).
10-06-2005 01:00 PM
10-07-2005 12:05 AM
11-04-2005 09:46 AM
Becktho,
Try TAB then SPACEBAR
It appears that (TAB + SPACE ) = Submit Post (well not always)
11-04-2005 09:47 AM - edited 11-04-2005 09:47 AM
oh yes..
it works if the cursor is within the message body box
it
.... it appears that if the cursor is within this box, simply pressing TAB submits it...
humm let's try (TAB)...
ok.. so
Message Edited by JoeLabView on 11-04-2005 10:48 AM
so if you press TAB, the first time you press the space bar, it will submit post...
Where's Ben & his forum bug list???
here goes (TAB)blablabklbnalbalbblablablablabla....(SPACE)
Message Edited by JoeLabView on 11-04-2005 10:50 AM
