Is there a way to 'comment' out code?
I don't know,
I don't even have 7.x, let along 8.0, so I guess it'll be a loooong time before I'll find out.
I just know what I read.
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
Message 31 of 39
(3,652 Views)
It would not suprise me.  There are usually artifacts left in released code for features that were dropped.  Duel scales on graphs were in a previous version, and when enabled typically caused LV to crash.  Delete from block diagram was in a couple of revisions before being formally put into the options, then the switch to enable 'hidden' properties and methods and so on.
BTW, I am not saying that there has not been work arounds for this stuff in the past.  I have been doing this for a little while... I am simply trying..although not successfully to say that this can be a more powerful tool than simply a way to comment out code.
Similar to when LV supported text and enum naming in the case structure.  That has developed into it's own programming architecture that was available, but much harder to do prior to that addition.
As for open G. Well I wish I had time to support that effort. Heck I am doing good to be keeping up with this thread alone!  Only cause I have not been sleeping well, did I even get onto this boards.
Paul
Message 32 of 39
(3,644 Views)
@becktho wrote:
wow - there's something strange going on.
just wanted to submit a message and out of a sudden there are four...
very strange....
Yes...  I had something similar happen to me the other day... I attributed it to possibly hitting the "TAB" key..
Maybe I should try again... it's a good way to tally up those replies in CC's list.. 😉
Nope...  TAB didn't automatically submit post..
JLV
Message 33 of 39
(3,599 Views)
@Khalid wrote:
Isn't the one included in 8.0 the same as the "hacked" / undocumented version from 7.x?
-Khalid
Not exactly. The one in 7.x was officially available with the PDA (and I think FPGA, too) module and was like a case structure for platforms - if you were running on windows, only the windows case would be enabled, running on pocketPC - you get the point. According to the documentation, this has only 2 states - enabled and disabled. The principle is the same, though.
___________________
Try to take over the world!
Message 34 of 39
(3,631 Views)
I addition to the Diagram disable structure, we also have the Conditional disable strucuture (Which has been around for a while, but is now directly available in the palette). It lets you define what executes depending on target type (Windows, FPGA, PalmOS, RT, Mac, Unix, and PocketPC).
Message 35 of 39
(3,608 Views)
Hello everyone,
As others have mentioned, there are two new structures in LabVIEW 8 that can disable or "comment out" LabVIEW code.  The Diagram Disable Structure has been discussed the most on this thread and is completely new to LabVIEW.
There is a second structure - the Conditional Disable Structure - for which you can create custom symbols that define which subdiagrams should be enabled.  For example, you can have a subdiagram in each of your Diagram Disable Structures named Debug == True and another named Debug == False.  From the Project Explorer, you can define the values for custom symbols like Debug (i.e. set Debug to True) and all of the Conditional Disable Structures with this subdiagram will be enabled when the VI runs.  This is a very simple example - you can actually apply much more complex logic if you so choose.
Happy wiring,
Mike N.
Message 36 of 39
(3,607 Views)
Hi JLV
Yes I remember vaguely that I also pushed the TAB-Button. I better not try to reproduce it (I want to increase my reply-number on a honest way Smiley Very Happy ).
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 37 of 39
(3,555 Views)
Becktho,
Try TAB then SPACEBAR
It appears that (TAB + SPACE ) = Submit Post (well not always)
Message 38 of 39
(3,501 Views)
oh yes..
it works if the cursor is within the message body box
it
.... it appears that if the cursor is within this box, simply pressing TAB submits it...
humm let's try (TAB)...
ok.. so
Message Edited by JoeLabView on 11-04-2005 10:48 AM
so if you press TAB, the first time you press the space bar, it will submit post...
Where's Ben & his forum bug list???
here goes (TAB)blablabklbnalbalbblablablablabla....(SPACE)
Message Edited by JoeLabView on 11-04-2005 10:50 AM
Message 39 of 39
(3,501 Views)
