Traditional daq devices not showing up in MAX
NI DAQ 7.4
PXI-1052
LabView 7.1.1
PXI-6602
PXI-6704
PXI-6251
We would like to use previous counter code. This is not working, since the traditional daq devices is missing in the 7.4 release. See the attached picture. Is there anyone who know why this is so?
Message 1 of 16
(5,938 Views)
I have a system similar to yours, except for the boards, and my MAX looks diferent than yours.
I have a traditional DAQ devices item to seach for the boards.
Mayb e during instalation of NI-DAQ 7.4 you missewd something...
Look at attachment,
Paulo
Message 2 of 16
(5,936 Views)
Paulo, thanks for the reply.
The difference between our configurations is that I have a remote PXI RT system.
Roger
Message 3 of 16
(5,929 Views)
Hello Roger,
Have you gone to 'Tools->Traditional NI-DAQ Configuration->Remote DAQ Configuration' and then in the dialog box that appears entered the IP address to your remote system? If you have done that correctly you will see a new dialog box appear labeled 'Remote DAQ Configuration' where you can see your Traditional NI-DAQ devices and set up everything.
Hope this helps!
Jimmie A.
Applications Engineer, National Instruments
Jimmie Adolph
Systems Engineering Manager, National Instruments Northern European Region
Message 4 of 16
(5,903 Views)
After some searching I found out that Traditional NI-DAQ has been removed in RT 7.1.
Regards
Roger Isaksson, Damill AB
Message 5 of 16
(5,851 Views)
Hello Roger,
can you please show me the sites, which told you that Traditional NI_DAQ has been removed in RT 7.1 for the remote machine?
I wanted to look at them myself.
I have the same problem like you using
PXI-1042 chassis
PXI-8186 controller
PXI-6704 and PXI-6030E device for DAQ
Regards, Jan
Message 6 of 16
(5,795 Views)
Hello Jan,
Have a look here:
http://digital.ni.com/public.nsf/allkb/A43DD6F680D123DD86256F870002B6A2
Cite: "For example, you will need to install the NI-DAQmx driver if you have an E series or M series board. Keep in mind that only NI-DAQmx 7.2 or above is supported in LabVIEW RT 7.1 and above"
http://www.ni.com/support/labview/real-time/drivers.htm
Here is another thread regarding synchronization, if that is the problem you are experiencing?
http://forums.ni.com/ni/board/message?board.id=270&message.id=1997&query.id=88261#M1997
Regards
Edit: Missing link
Message Edited by Roger Isaksson on 11-01-2005 03:44 AM
Message 7 of 16
(5,778 Views)
Jan, there is one thing more that I recalled from the thread with the 1052 problems,
DAQmx 7.5 and LV RT 7.1.1 seem to detect E series cards with these versions, but not with the older versions.
"The DAQmx 7.5 and LV RT 7.1.1 seem to detect E-series cards now)! When configuring the SCXI modules the chassis emits a "click", that wasn't present before. "
Roger Isaksson
Message 8 of 16
(5,775 Views)
Hello Roger,
thank you for answering quick.
But my problem is not the DAQmx, there I can see both devices.
I cannot see the traditional NI-DAQ.
I tried allready the steps from this site
http://digital.ni.com/public.nsf/allkb/34E111C6BB6868998625704600724AEE .
But my chassis is not listed, wehn I trie to add something.
Do you know how to activate traditional DAQ?
With my DAQmx I have also some problems.
I created a device like the examples you can find in Labview, but it cannot read or write from this channel.
If I put a voltage on that channel, it doesn't show up on my VI front-panel.
I tested the device with the test-panel of the Automation-explorer MAX, but there was no error.
Regards, Jan
Message 9 of 16
(5,763 Views)
Hello again Jan,
I don't think the RT 7.1.X has support for the traditional daq drivers together with a M- or E-series card! Maybe some NI support engineer can answer/verify this?
You could attach the VI, so I and others can have a look at your lv code?
Regards
Message 10 of 16
(5,761 Views)
