Is it possible to trigger the next event from within the event case?
I have a rather complicated event that is triggered by a change in value of a particular button in the interface. In some cases, I want to alter that button's value when handling other events. But when I do this, the event handling a change in value for that button does not get triggered. Is there a way to make sure the value change event gets handled at the next iteration of the while loop in which the event structure sits?
(2,436 Views)
Accepted by kgolden
Hi kgolden,
how do you change the value? If you use a property node, then you can use value(signaling) instead of only value.
Mike
(2,433 Views)
Hi Mike,
Thanks! I was using properties and did not previously know what the value(signaling) was. Knowing this will really help me clean up a lot of redundant code.
(2,427 Views)
