03-25-2011 02:11 PM
I have a rather complicated event that is triggered by a change in value of a particular button in the interface. In some cases, I want to alter that button's value when handling other events. But when I do this, the event handling a change in value for that button does not get triggered. Is there a way to make sure the value change event gets handled at the next iteration of the while loop in which the event structure sits?
03-25-2011 02:17 PM
Hi kgolden,
how do you change the value? If you use a property node, then you can use value(signaling) instead of only value.
Mike
03-25-2011 02:40 PM
Hi Mike,
Thanks! I was using properties and did not previously know what the value(signaling) was. Knowing this will really help me clean up a lot of redundant code.
