Is it possible to make labview give out a warning if you try to close it when it's still running?
I am using Labview 7.0. It seems that when I try to close a running program, it just closes without any warning. I was wondering if there is any way to adjust it so that a warning could pop up to avoid accidentally closing? Thank you.
(3,225 Views)
Maybe you could just disable the possibility to close the running program by removing the "close box"
On the main VI window, go to VI properties (by right-clicking on the VI icon (top-right corner)) > window appearence > customize
There you can set many things 😉
Message Edité par TiTou le 12-06-2006 04:38 PM
Epictetus
Antoine Chalons
(3,223 Views)
There is the panel close event that will let you catch the close.
Ben
Message Edited by Ben on 12-06-2006 09:44 AM
(3,216 Views)
I think that's the best way but you can also trap and discard it by using an event structure. The shipping example called Event Conditional Stop does this.
(3,211 Views)
Thank you guys, that helps a lot!
(3,208 Views)
