Is it possible to have dummy for a control
Hi
In my program,i have a control inside a case structure & i have clustered this control to make it invisible in next cases.is it possible to use the same control in next case(since i have clustered i am getting a broken wire).
Message 1 of 31
(4,645 Views)
That must be a small bug . Post your code, please!
Software developer
www.mcm-electronics.com
PORTUGAL
Message 2 of 31
(4,634 Views)
Can you post your code?
R
Message 3 of 31
(4,620 Views)
Thanks Jorge
I have attached the VI.
Message 4 of 31
(4,619 Views)
Vi is here
Message 5 of 31
(4,616 Views)
EDIT: (you posted the code faster than I could type)
Message Edited by JoeLabView on 07-03-2008 08:50 AM
Message 6 of 31
(4,615 Views)
I'm looking at the code, but do not understand what it is supposed to do.  Why do you need a cluster?
Actually, describe what you are trying to do, and we'll look at how to implement that.
R
Message 7 of 31
(4,608 Views)
Just select the cluster local variable, and unbundled it....
as you did, with the normal control
Message 8 of 31
(4,604 Views)
Move the cluster outside the case structure and run the wire in.
Lynn
Message 9 of 31
(4,600 Views)
I don't get it, but here is a corrected version..
Maybe I should post this LOL! 😄
Message 10 of 31
(4,598 Views)
