Is it possible to have dummy for a control
Just looked at Lynn's..  LOL!  Well.. at least we had the same idea..  😉
Message 11 of 31
(1,590 Views)
I'm not really sure to understand what you want but if u want read the cluster in other case u can put it on outside the case structure.
But you want it doesn't appear for other case, in this case, you can use local variable (right click-> create-> local variable) and put it on other case of your case structure.
But if u want that your cluster doesn't appear in the front panel for other case, i think it will be better to read the cluster before your case structure and use node property in thise structure to put the cluster invisible.
I hope you have understood.
Message 12 of 31
(1,586 Views)
Thanks Everyone
All your answers is close to my problem
I dod apologize if i have not explained properly when i posted the question.
As in my vi,i am using ring control in different cases.for ex, from the control in case1 i select few options and disabled(using property node) the selected options. in case 2 i need to have ring control where i can select only the options i have selected in case1.(i,e for ex,in case1 ring control if have options like,A,B,C,D and if have selected A,C,D then it goes disabled on each selection, when we are coming to case2 i need to have possibilty to select only A,B,D not B becoz since it is not selected in case1).
Thanks.pls let me know if i am not clear.
Message 13 of 31
(1,578 Views)
I think this is what you need...
Message 14 of 31
(1,570 Views)
Thanks pnt
Could you pls explain me,how it works
Message 15 of 31
(1,540 Views)
You read all the ref. from the cluster, (here is only one), and then select the one you need.
At the end you use a property node to disable the items you want.
But because Labview does not know what kind of ref. is the input, you must use the "to more specific class", to get the correct properties
Message 16 of 31
(1,509 Views)
Thanks pnt
Message 17 of 31
(1,495 Views)
4 stars? Why?
You could just not rate my answer at all. It would be better....
Never mind....
(i suppose you know, anything less than 5 stars is a negative rate)
Message 18 of 31
(1,484 Views)
sorry was it 4star,i think i clicked the wrong one.i am really sorry for that
Message 19 of 31
(1,481 Views)
Dear pnt,
we will support in the ratings. here u go......
Mathan
Message 20 of 31
(1,477 Views)
