01-19-2006 02:44 PM
01-19-2006 02:48 PM
01-20-2006 12:59 AM - edited 01-20-2006 12:59 AM
Message Edited by devchander on 01-20-2006 01:00 AM
01-20-2006 01:12 AM - edited 01-20-2006 01:12 AM
Hi Arron,
Oops a small mix up! ![]()
Index array of each channel and use 'convert to dynamic data' function
look at attached VI
Regards
Dev
Message Edited by devchander on 01-20-2006 01:13 AM
02-03-2014 02:29 PM
is it possible to convert a Cluster of 3 elements to dynamic data? I have a signal in the time and I have to find the POWER SPECTRA in the frequency. The problem is that first I must fix the step in the x axis for the signal in the time otherwise the x axis (frequency) in the power spectra is wrong.
Alternatively, it's possible later change (inthe power spectra) the values of a signal in the (x) axis of ascissae? Thanks
02-03-2014 02:37 PM
02-03-2014 02:47 PM
First of all, use the Build Waveform to combine your Y data and a dt.
Secondly, use one of the FFT functions in the Signal Processing->Waveform Measurements palette. Then there will be no conversions to the dynamic data type.
