Is it possible to convert a Cluster of 3 elements to dynamic data to use with express vis?
I have a waveform graph created from a cluster of 3 elements. Is it possible to convert this to dynamic data to use with express vis.
I have bundled the information for the waveform into a cluster. The source is the cluster of 3 elements the sink is dynamic data.
I am working towards making a FIFO to use in a pretrigger VI. -Thanks
(4,551 Views)
Here is a screen shot to help. -Thanks again!
(4,544 Views)
Hi Arron,
Index out each channel's  row /column from the 2D array , bundle the individual graphs, use build array and display as shown in this VI
Hope this helps
Dev
Message Edited by devchander on 01-20-2006 01:00 AM
(4,531 Views)
Hi Arron,
Oops a small mix up! Smiley Wink
Index array of each channel and use 'convert to dynamic data' function
look at attached VI
Dev
Message Edited by devchander on 01-20-2006 01:13 AM
(4,528 Views)
is it possible to convert a Cluster of 3 elements to dynamic data? I have a signal in the time and I have to find the POWER SPECTRA in the frequency. The problem is that first I must fix the step in the x axis for the signal in the time otherwise the x axis (frequency) in the power spectra is wrong.
Alternatively, it's possible later change (inthe power spectra) the values of a signal in the (x) axis of ascissae? Thanks
(4,007 Views)
You can simply use the Build Waveform function.
(3,997 Views)
First of all, use the Build Waveform to combine your Y data and a dt.
Secondly, use one of the FFT functions in the Signal Processing->Waveform Measurements palette.  Then there will be no conversions to the dynamic data type.
(3,991 Views)
