07-11-2006 04:34 AM
07-11-2006 07:17 AM
07-11-2006 09:11 AM
07-11-2006 09:46 AM
07-12-2006 02:02 AM
Hi Michael,
According to your message and what I read on the link, it seems only the four tools (Visual Studio 2005 Standard or Professional Edition, ActiveSync 4.1 or later, Windows Mobile 5.0 SDK for Pocket PC, & Visual Studio 2005 Device Command Shell) are required.
But the fact is when I compile with only those tools installed, I get an error.
Any idea what else could cause the error ?
According to Bob and Paolo, installing the eMbedded Visual C++ 4.0 and the Pocket PC SDK will solve the problem. Which I am sure it will since on another computer I had these tools installed and it worked. But in that case, I am unsure which compiler will be used and if the Windows Mobile 5.0 functionnality will be available.
Yvan
07-12-2006 10:37 AM
07-13-2006 01:54 AM
Michael,
The error I get is that LabVIEW never finished properly compiling my application. The build report says that "clarm" and "link" are no valid commands : this can be seen in the build report attached to my first message.
Attached to this message you will find how my project looks like.
Thanks for your time,
Yvan
07-13-2006 10:17 AM
07-14-2006 04:53 AM
Michael,
That's exactly what you explained : creating a new target just solved the compiling problem without the need to install the other tools.
Thanks very much for you help,
Yvan
