plot line like line graph in excel instead of like XY scatter
Is there a way to make a graph that is like the line graph in excel (see pic) and not like the normal graph that is like an XY scatter??
I am using the XY Graph and am trying to graph data that is of the form
x         y
0         0
1         1
2         2
3         3
4         4
3         3
2         2
1         1
0         0
This ends up plotting over itself in the normal graph.
Kenny
Kenny
(4,393 Views)
There is a property node where you can assign marker values as an array to each scale.
(4,375 Views)
I just tried that using the "Xscale.Markervals[ ]" property node and it gave the same results as before.
Kenny
(4,374 Views)
You can do an XY graph on a picture control. If you go inside the PlotXY.vi, then the Draw Cartesian Axes.vi, then the Draw Axes.vi,  there is an X-scale specs array indicator that contains the text for the axis labels. You can hijack the label text. You will need to invert one set of X values to get the data centered around zero. Then write whatever text values you want.
Message Edited by unclebump on 07-13-2006 05:12 PM
(4,369 Views)
Here is an .llb with the option to remove the '-' sign on the X scale labels by using a boolean input.
(4,341 Views)
