10-02-2009 10:30 AM
Solved! Go to Solution.
10-02-2009 10:35 AM
10-02-2009 10:36 AM
In the first sentence, you say that your VIs are compatible with LabVIEW 2009? Does that not answer your question? 😉
More details here.
10-02-2009 11:10 AM
Christian, I think what was meant was that they were compatible upto 2009, but that the "In Range and Coerce", but that "include upper limit" hadn't been selected.
As to backwards compatible, if it has worked for the versions up to 8.6 there shouldn't be any problems of compatibility other than actually loading, which would be fixed by opening the older vi in 8.2+ and saving at that version.
10-02-2009 12:25 PM
Saving in 8.2, and then re-opening in Labview 2009 helped some of the vi's, but the Writing vi's are still give errors:
Output Buffer iIs Full Value Not Sent!.
Should I try opening the drivers in 8.6 (If yes, do you have a link to an eval. version of 8.6)?
I've added the files if anyone would like to take a look. They are intended to be unzipped under the
C:\Program Files\National Instruments\LabVIEW???\instr.lib
directory. If you run the file "WriteDemo.vi", you'll see the error message "Output Buffer Is Full.." which is not supposed to happen.
Thanks for your help so far. Unfortunately I have almost no experience developing with Labview.
10-02-2009 12:29 PM
The drivers are used to talk to Qlarity which is a free download here:
http://www.qsicorp.com/engfiles/Qlarity%20Foundry/QlarityFoundry2_60_setup.exe
10-02-2009 04:23 PM
10-02-2009 04:53 PM
QlarityEng wrote:
I'm still having the problem with the Write.vi.
There are about 16 different write_____.vi. Can you narrow it down a bit?
10-02-2009 04:58 PM
10-05-2009 09:56 AM
Is the two versions back compatibility applicable if I open my .vi in 8.6, it works, I save it, and then re-open in Labview 2009?
I have a customer who is planning to upgrade there system to Labview 2009 using these vi's, so any help would much appreciated. They had upgraded to 2009 which broke compatibility so they downgraded back to 8.6.
