Data Acquisition between NI 9263 and NI 9205
Single channel set up works, but multiple channel gives an error message.  How do I set up multiple channels to read/write voltages between the NI 9263 and NI 9205?
Message 1 of 12
(4,254 Views)
So, you are running analog input and output at the same time? How exactly have you set this up? A screenshot of the code will help. Also, what sort of error are you getting?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
Message 2 of 12
(4,242 Views)
I happen to be working on the very same problem between the 9263 & 9205.  I have attached my VI for you to see how I've set up communication between the two using a single channel from each.
I would now like to send a Vout from the 9263_ao1 to the 9205_ai1 and read them both on the graphical output.
FYI: First Time NI User, I have read about type-C modules but haven't yet fully understood the timing issues I beleive are necessary to make this happen.  Your help is appreciated.
Message 3 of 12
(4,227 Views)
Brian11 and Braxtonlewis,
What error message are you getting when you tried to setup multiple channels?
Ben Sisney
FlexRIO V&V Engineer
Message 4 of 12
(4,200 Views)
Error Received after adding a second output channel from the 9263 to the VI attached above.
Measurements: Write cannot be performed, because the number of channels in the data does not match the number of channels in the task.
When writing, supply data for all channels in the task. Alternatively, modify the task to contain the same number of channels as the data written.
Number of Channels in Task: 2
Number of Channels in Data: 1
Task Name: _unnamedTask<3>
Message 5 of 12
(4,183 Views)
braxtonlewis,
Thanks for the information! However it doesn't seem that you're attached screenshots worked. Can you try to upload them again using a .png extension? Was there an error number associated with that message?
You could also attach the VI that is giving you this error as well.
Thanks!
Message Edited by Ben S on 07-27-2009 10:48 AM
Ben Sisney
Message 6 of 12
(4,174 Views)
Putting the channels in a list, for each module, has worked.  Thanks for your help.
Message 7 of 12
(4,158 Views)
Brian11,
Could you explain what you mean by "putting the channels in a list, for each module".  As I stated before I'm very new to LabVIEW.
Message 8 of 12
(4,156 Views)
braxtonlewis,
I am at work right now, but will try to post my solutions later.
Message 9 of 12
(4,153 Views)
All,
Here are some really good DAQmx and DAQ Assistant Tutorials that give lots of great info.
Getting Started with NI-DAQmx
Learn 10 Functions in NI-DAQmx and Handle 80 Percent of Your Data Acquisition Applications
NI-DAQmx Express VI Tutorial
Ben Sisney
Message 10 of 12
(4,143 Views)
