Intesity Graph Ramp Autosize
Hi all,
I am using intensity graph, and I want the ramp to be automatically resize (during run time) when the graph is resized. Is there a way to do that programmatically?
I checked bound (ZScale.Area.Height) but it is read only property.
Thanks & Regards,
Irfan
(CLD)
https://haliatech.com/
Message 1 of 9
(3,077 Views)
Accepted by irfanabid
Short answer: NO.
Slightly longer answer (spoiler: probably not what you want to hear):
The resize dialog can resize the colored part of the Z-Scale. It uses a VI (\resource\dialog\Resize.llb\PosDims.PasteToTargets.vi) to do this. The VI is locked, but using  it is pretty straightforward...  IFF, you have a reference to the scale's colored part.
The (only?) way to get it (it's not the ref returned by the property) is to get the UID from the selection (obtained from the graph while the VI is idle) and then use yet another LV API call to get the reference from the UID... And even then, you'd only be able to scale the colored part and hope the scale behaves and scales with it.
So possible: yes. Easy: NO.
Message 2 of 9
(3,021 Views)
Thanks for the response. I hope in the future, this can be resized.
Thanks & Regards,
Irfan
(CLD)
Message 3 of 9
(2,999 Views)
Maybe some day.
Note that even the graph control itself can't be scaled through properties (you can with the VI mentioned earlier). With properties have to scale the graph area and calculate the size of the control from that...
Message 4 of 9
(2,995 Views)
Yes, but for graph, I can use splitter and set scale object with Pane, so it can resize when the window resized.
For intensity graph/chart, only the graph portion that can resize, using the above method, but not the ramp.
Thanks & Regards,
Irfan
(CLD)
Message 5 of 9
(2,965 Views)
Absolutely right.
I was just stipulating that the scaling of FP objects is a big inconsistent mess.
I labored over this before. See (the links mentioned in)  GitHub - Dynamic-Scaling: Dynamic UI Scaling Toolkit for LabVIEW for inspiration. It won't help with the Z-Scale though, as there's no way to refer to the FP's object.
Message 6 of 9
(2,944 Views)
You could use a second narrow intensity graph that only shows the y scale where you would graph a 2D ramp where z=y.
Message 7 of 9
(2,916 Views)
I've done that a few times.
Basically a DIY Z Scale in a separate control.
Message 8 of 9
(2,904 Views)
Thanks. It works.
Thanks & Regards,
Irfan
(CLD)
Message 9 of 9
(2,865 Views)
