Interpolating 2D array
You mean to create a file path constant,but how it will be piossible to change file on front panel? Or I missunderstand smth
Message 11 of 49
(4,040 Views)
Could you share .vi file please,if It`s possible
What am I doing wrong?
Message 12 of 49
(4,036 Views)
No idea what you are doing wrong...
Perform the following steps:
- Place the "Read Delimited Spreadsheet" vi on a block diagram
- right-click the "all rows" output and create indicator
- run the vi.
You might have the double display-formatted incorrectly?
Currently using LabVIEW 2022
Message 13 of 49
(4,025 Views)
So,thank you. I`ve already solved this porblem,it was because of global parameters of decimal on my computer.I`ve change this on dot and It works correctly now. Excuse me for my slowpoke in this question.
Then. I`ll have no ideas how to interpolate between  this two arrays to find new S-parameters for new current.
Message 14 of 49
(4,018 Views)
Hi Yolo,
@HoloYolo wrote:
I need to interpolate between two adjacent coloumns in final array which was created from this 2 files as it shown on block diagramm.
How do you want to interpolate between these two columns?
Do you need just the mean of each pair of columns: then you don't need any interpolation function!
When you really want to interpolate: which parameter decides the interpolation point (aka x value)?
Message 15 of 49
(3,996 Views)
As I`ve written earlier I have 2 files with S-parameters for given frequencies for 2 currents-2 mA and 5 mA. I think to use 2D Inerpolate block in LabView to do it,to interpolate between this 2 parametrs for current,for example to make outpur parameters for 2.5mA. But I don`t know how exactly It can be realized,Interpolate doesn`t work. For Z-value is combined data from 2 files,for X-frequencies from file and for Y-current 2-5.
Message 16 of 49
(3,994 Views)
Hi Yolo,
did you notice my comments on using real ZIP files and "only English" filenames?
Suggestion:
Message 17 of 49
(3,982 Views)
Oh,thank you so much for help,I`ll test this block and tell you how it is.
I`m sorry I forgot about english files and ZIP,in the future will attach with it.
I just think that visualy this interpolation looks like this,so I thought to use 2D interpolation.
For example,what should I do,if i have more files:for 10,15 mA and I want to interpolate for whole range,from 2 to 15 mA. I need to expand loop block with more arrays?
Message 18 of 49
(3,949 Views)
I`d like to know,how is it function nammed and what does this function perform?
Message 19 of 49
(3,947 Views)
As the name suggest, it builds a cluster array.
Message 20 of 49
(3,929 Views)
