Interfacing Microchip ICD3 With Labview.
Here is what I tried. But unfortunately after I press program it takes 23 sec for programming second time.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 41 of 50
(4,717 Views)
The time spend on each call should roughly be the same. Unless there are connection issues etc.
Message 42 of 50
(4,689 Views)
This is what I want to say. If you have used ICD then first time that also take 30 sec approx. but when user selects program then it take 5 sec to program. how to achecive this here
--Ranjeet
Message 43 of 50
(4,687 Views)
If on each program button press, it takes 25 sec then its not the correct way I think, but it should take 5-7 sec at the max as I verified with ICD programmer.
--Ranjeet
Message 44 of 50
(4,686 Views)
I know this thread is old but has anyone been able to get MPLABX IPE to work with this?  I have an ICD3 and am trying to program a PIC24FV32KA304.  I keep getting Error code 267.  I have updated the path to point to my ICD3CMD location but I'm just not able to get it to program.  I get Device Not Found.  I can program directly from MPLAB_IPE, just not via Labview.  Any help would be great.
Thanks.
Message 45 of 50
(4,452 Views)
I need PIC programming with PICKIT3 or PICKIT2 using labview, let me know how to do it
Message 46 of 50
(4,173 Views)
I've successfully completed projects pickit 2 and pickit 3 with labview interface
you must install mplab x ide v2.2 or later
http://www.microchip.com/forums/m819557.aspx
you have any problem for this i can help you
Message 47 of 50
(4,161 Views)
Message 48 of 50
(4,184 Views)
your work can help me to trigger the pickit3 with labview?
Message 49 of 50
(3,457 Views)
can you help me ??? I try to connect pickit 2 with pic 16f877a with LabVIEW can I do this (connect pickit 2 with LabVIEW) and How by steps???
Message 50 of 50
(3,060 Views)
