Installer source location reverts to cd after selecting C drive with browse
When specifying the installer properties on the additional installer page, there is a box on lower right for specifying installer source location.  For NI VISA Runtime 3.4.1, the location is set to D:\Vision 8.0.0 Acquistion Software.  I use the browse option to set the location to C:\Programfiles ... but  it won't save the new location.  If I select another installer and then return to Runtime 3.4.1, the location is back to D:\ ... .  When I build the installer, I get a popup saying it can't find the installer at D:\   .  If I use the browse button to set the location to C:\ ... , the build continues successfully.
(2,638 Views)
This is a known issue. There are many post out there (if you had searched) that will help you through this.
There are two ways to get around this.
  1. Copy the entire contents of the CD to your hard drive and reinstall everything from there.
  2. Have the CD handy and use the CD.
The reason why it does this is because is will always look for the last place it was installed from.
Joe.
"NOTHING IS EVER EASY"
(2,633 Views)
