Finding "digital single write.vi" and "digital group config.vi" for DAQ6507
i am looking for the following two vi's:
digital single write.vi and digital group config.vi, as mentioned and required by the example on:
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3E73956A4E034080020E74861&p_node=201227&p_source=External
can someone please help me with this?
thanks!
-gjs
(3,563 Views)
As mentioned on that page, you need traditional DAQ installed. The latest version can be downloaded from http://digital.ni.com/softlib.nsf/websearch/3DBF3D343476A28F8625709E006A4937?opendocument&node=132050_US
(3,552 Views)
i will try that. thanks a lot!
(3,544 Views)
Hi
I tried to install the "Traditional NI-DAQ" from the link you suggested and installed it as well. But when I tried to run "Digital Multiple Write.vi" again, it still searched for the same two files and could not find them in the end. I searched and couldnt find it either. But maybe I was not looking in the right place...?
Any pointers will be greatly appreciated.
Thanks a lot!
-Gaurav
(3,512 Views)
Hello Gaurav,
After you install Traditional DAQ, you should have access to these VIs, if you installed the correct version of Traditional DAQ for your system and LabVIEW.  The link given above is for Traditional DAQ 7.4.1 which works with LabVIEW 7.0, 7.1 and 8.0.  If you do not have one of these versions, the LabVIEW support is not installed and that would be why you cannot open the example.
Therefore, if you are using LabVIEW 6 and you want to run this VI you will need to install an older version of DAQ.  To see what versions of Traditional DAQ are available for your version of LabVIEW please look here
If this does not help you out, can you please post back which version of LabVIEW and Traditional DAQ you have installed?
I hope this helps,
Jesse O.
Applications Engineering
Jesse O. | National Instruments R&D
(3,501 Views)
Hi
Yes it did help a lot! I installed 7.1 and it works now 🙂
Thanks a ton!!
-Gaurav
(3,489 Views)
