Installer builder not flexible enough
Hello
I use the installer builder to create an installer for my application, but it lacks some flexibility.
For example I would like that it installs some files only under certain conditions, such as existence of some files on the disk, or according to the value of a new tickbox/button in the installer.
What would be the easiest way to accomplish that?
I already thought at using a completely different installer builder, such as Inno Setup, but then I loose all the benefits of the LabVIEW installer builder such as runtime installers, LabVIEW API...
(2,625 Views)
@awilliotAcutronic wrote:
I already thought at using a completely different installer builder, such as Inno Setup, but then I use all the benefits of the LabVIEW installer builder such as runtime installers, LabVIEW API...
I think a 3rd party installer is the usual solution. I've also seen installers being build in LabVIEW, so the LV exe is run after the installer is done. But it's a lot of work to make nice screens.
I think you normally a) add Inno installer to the LabVIEW installer, or b) add the LabVIEW installer to the Inno installer.
(2,616 Views)
Yup as much as I'd like it to be part of the builder process, I too use Inno setup and ISTool.
https://forums.ni.com/t5/LabVIEW/LabVIEW-installer-with-Inno-setup/m-p/3688270#M1037104
NI installers are quite intelligent for the most part.  If you run an NI installer that contains DAQmx, VISA, XNet, and the Run-time engine.  It will only install the components that aren't installed (or are installed but a different version)
(2,586 Views)
