Inserting new data to a new row in same Excel sheet continuously
Accepted by ery
Replace the Open New Worksheet function (so it doesn't make a new worksheet when you open the Workbook) then you need to find the next row to write in (unless you want to replace data).  I've written a VI that does this and replaced the Row constant with the next row from the last time the Workbook was saved.
Jim
Message 11 of 26
(2,232 Views)
Can you please include the open specific worksheet.vi for me? since I don't know why I couldn't open that VI
thanks a lot Jim, you are the best ^^
thanks again,
Ery
Message 12 of 26
(2,228 Views)
Thanks, Problem solved!!
Thanks Jim ^^
Message 13 of 26
(2,225 Views)
Hi Jim, Sorry to bother you again, I just wonder how do you connect the get next xl row.vi to the cell value? I try to use the function you posted, but it's now working, I actually need to get next xl column instead or row, since I need the output value to excel set to next column everytime I finished recording and save the excel and run it again.
thanks again,
Ery
Message 14 of 26
(2,210 Views)
Hi, Ery.
I'm not sure I understand what's not working, but you can rewire the output from the attached VI and it will give you the next column number.  I've modified it to return the next column as well as row.
Jim
Jim
Message 15 of 26
(2,205 Views)
Hi Jim,
I try to wire the output of get next row & column but it couldn't be connected, I attached the picture and my vi
thanks,
Ery
Message 16 of 26
(2,202 Views)
Oops.  I don't know when it happened, but there was a class conflict.  I had the terminal wired incorrectly, but that doesn't tell me how the type changed.  Anyway, here's a corrected VI.
You may also need to modify the wiring a bit to get the
or, this
depending on what you're trying to do.  Regardless, you can't set the column tunnel to Use Defaults if Empty because you'll get a zero every time after the first loop.  Use a Shift Register to carry it back around.
Jim
Message 17 of 26
(2,198 Views)
Yeap, thanks, it's working now, but the system seems a bit wierd, I attached the picture show how exactly what I need when run and stop then run again this vi which show the result on excel
Ery
Message 18 of 26
(2,196 Views)
You need to understand how the Shift Register works with the Case Structure.  The True case is where you put the initial Row,Column pair.  You want the row to always start at 1 and the column to start with whichever is next.  The false case is where you'll increment the cell position.  You want the row to increment and the column to stay the same.  As Nike says: "Just do it."
Jim
Message 19 of 26
(2,190 Views)
Thanks Jim, Just as you said, I put it that way, but I keep getting the next row(1048577) and Next Column(16385) which is nothing show on the excel
Ery
Message 20 of 26
(2,174 Views)
