Inserting new data to a new row in same Excel sheet continuously
That's what happens when I don't test my code...
I've tested this.
Jim
Message 21 of 26
(1,065 Views)
Sweet!! THanks again Jim, you help me a lot. thanks, it's working perfectly now, ^^
Have a good day there!!
Ery
Message 22 of 26
(1,063 Views)
Sorry for reactivating this thread, i tried out the above example, but the problem is that when i run my vi first time its correct, when for the next time, the output is not shifting to next row?
Message 23 of 26
(957 Views)
Then show us your code.  You likely miswired something.
Message 24 of 26
(922 Views)
Please, start a new Thread.  Tell us what you want to do, and post the code you are trying to use to do it.  Both of these steps are important -- the first because we need an accurate description of the Problem/Task, and the second to give us a reference point for what you have tried.  Note that a "solution to another problem" that is several years old might not be the best solution for your (probably different) task.
But most important, Start a New Thread (meaning post a New Message).
Message 25 of 26
(913 Views)
Can you send me the subVi pls when I open the Vi that you have attached the subvi are showing in question mark. I am using LabView 14
Message 26 of 26
(838 Views)
