09-16-2010 10:41 AM
I am wanting to change the basic controls that labview has (the toggle switches, etc...) so they look like your microsoft controls that most people are use to seeing (the save button, open, etc...) Does active x allow you to use those controls that microsoft has to do the same as if you added a toggle switch to save data?
guilio
09-16-2010 11:39 AM - edited 09-16-2010 11:41 AM
You should check out the systems palette, it contains a lot of controls that follow the default OS style (buttons, tree, listboxes, radio-buttons).
What exactly do you mean by a 'toggle'? Do you mean a checkbox:
That's available in the System palette as well.
The Eyes on VIs blog focusses a lot on User Interface design.
There's also a Community group on User Interface design.
Ton
09-16-2010 12:02 PM
I mean more like if you open work, you have the graphical buttons for save, print, open, etc....those style buttons. The check boxes are ok, but IMHO, if I'm making a program for distribution, it tends to make the program look older than if I had graphical buttons.
09-16-2010 01:19 PM
You should check out the UI Interest Group. There you will find the "Missing" System Control Suite with a lot of graphical buttons.
09-16-2010 02:23 PM
I really (really) like the UI Tools distributed via LAVA:
And especially the Vista Pack, they have nice visual effects.
Ton
09-16-2010 02:35 PM
Ton
Oooohhh... those are nice.
09-20-2010 07:40 AM
Agree, very nice....question now, how do I install it. It is showing ogp? Am I missing something?
TWK
09-20-2010 07:57 AM
TWK
No you're not missing anything obvious.
An OGP file is an install file that can be installed usint VI Package Manager.
Ton
09-22-2010 09:24 AM
Very nice icons.
Got another question. I installed it, but under my user lib on front panel, it is now showing up. Is there a way to refresh or get this added?
09-22-2010 10:04 AM
It should automatically refresh (at least that is default for VIPM).
Perhaps is installing the Lava LIB UI tools the solution (link).
Ton
