Input given from Index array type doesnt match for "case structure" ??
when i try to give Input from Index array type doesnt match for "case structure"
All i have is an input array and in which i take only some index, so i have index array
then i wanna check whether that number matches through the "Case Structure"
But the type doesnt match
Error is type mismatch like  source is 1D array of unsigned byte
                                          &  sink is long.
Should i convert or something else  ??
Thanks in advance
Praveen
(3,304 Views)
Best way to get help is to post a VI as an attachment or at least an image of the block of code causing problems.  Preferably as a .png, never as a .bmp.
(3,294 Views)
If you are using an Index Array function and the output is a 1D array (the source), then you are indexing a 2D array. The difference between a 1D and 2D array are pretty clear if you look at the type of wire. A 1D array is a solid thick line. A 2D array is 2 thin lines. You can't wire a 1D array to a case statement. If you wire up both row and column inputs of the Index Array, you'll get a scalar out.
As Ravens Fan mentions, though, attaching an image or the actual code will help everyone understand what exactly you are doing.
(3,291 Views)
 Thanks,,i will check. i am member of other boards,yes example should be given.
  i tried inserting image, but it prompts for URL server which i dont have.
  Is there an easy way to attach the Snap Shot  or Picture ?
~Praveen
(3,278 Views)
You can add a file to you post as attachement.
Ton
My LabVIEW Ideas
(3,275 Views)
