If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
Input given from Index array type doesnt match for "case structure" ??
when i try to give Input from Index array type doesnt match for "case structure"
All i have is an input array and in which i take only some index, so i have index array
then i wanna check whether that number matches through the "Case Structure"
But the type doesnt match
Error is type mismatch like  source is 1D array of unsigned byte
                                          &  sink is long.
Should i convert or something else  ??
Thanks in advance
Praveen
(3,312 Views)
Best way to get help is to post a VI as an attachment or at least an image of the block of code causing problems.  Preferably as a .png, never as a .bmp.
(3,302 Views)
If you are using an Index Array function and the output is a 1D array (the source), then you are indexing a 2D array. The difference between a 1D and 2D array are pretty clear if you look at the type of wire. A 1D array is a solid thick line. A 2D array is 2 thin lines. You can't wire a 1D array to a case statement. If you wire up both row and column inputs of the Index Array, you'll get a scalar out.
As Ravens Fan mentions, though, attaching an image or the actual code will help everyone understand what exactly you are doing.
(3,299 Views)
 Thanks,,i will check. i am member of other boards,yes example should be given.
  i tried inserting image, but it prompts for URL server which i dont have.
  Is there an easy way to attach the Snap Shot  or Picture ?
~Praveen
(3,286 Views)
You can add a file to you post as attachement.
Ton
My LabVIEW Ideas
(3,283 Views)
