Initialize and increment a fractional number.
I need to use a looping structure wherein a variable needs to be initialized by a user control (or upstream calculation) before the loop and incremented within by a fractional amount. For example the variable could range from 0 to 2 pi in increments of 0.01 and roll over at 2 pi, but it may need to start at 3.07.
My main problem is how to set a loop variable outside or before the loop starts. Is 'variable' a valid term in a data flow concept?
Thanks.
(3,513 Views)
Use a shift register. initialize it with the start value and increment it at each iteration by adding the increment.
(3,503 Views)
(3,490 Views)
(3,489 Views)
It's called a control. Put it outside the loop, inside another one which will stop when the operator enters his/her number.
Have you gone through any of the online tutorials on LabVIEW? They should be able to at least quickly give you the basics, and very basic questions are what you are asking about.
Cameron
To err is human, but to really foul it up requires a computer.
The optimist believes we are in the best of all possible worlds - the pessimist fears this is true.
Profanity is the one language all programmers know best.
An expert is someone who has made all the possible mistakes.
To learn something about LabVIEW at no extra cost, work the online LabVIEW tutorial(s):
LabVIEW Unit 1 - Getting Started</ a>
Learn to Use LabVIEW with MyDAQ</ a>
(3,487 Views)
Thanks.
Good Question!
And no, "Variable" is a poor term for anything in LabVIEW.  In LabVIEW (To slightly over-simplify) there are really only four concepts we need to master: Data, The Node, The Wire and The Synchronization Boundary.  "Data travels from node to node, along wires, when sychronization boundary criteria are met."  Dataflow in one sentance.
"Should be" isn't "Is" -Jay
(3,485 Views)
