Read/Write Array in Event Structures
I want to read&write byte memory contents of my EUT in a 2D Array in an event structure. I think I got that done and created a property node help to that. Now I want to be able to read/write certain bytes  of the memory in a different event structure. Seems like I need a property node but don't know how to pick off the desired bytes.
(2,625 Views)
Hi runna,
maybe you should provide some more information on all the mentioned items and their connection ("byte memory contents"?, event structure?, EUT?, 2D array?, property node?). And maybe you should provide a simple demonstration VI too?
(2,618 Views)
