In the shared variable properties box, when enabling aliasing, what is the difference between binding to a project variable vs. to a psp url
In the shared variable properties box, specifically with regard to a the target being an rt target, when enabling aliasing, what is the difference between binding to a project variable vs. to a psp url?
(3,557 Views)
The difference is in the type of variable you are binding it to.  A project variable is a variable that lives within the specific project in which it was created.  A PSP URL is an address using the Publish-Subscribe Protocol (PSP).  You can learn more about PSP URLs here: https://www.ni.com/docs/en-US/bundle/labview/page/sharing-live-data-programmatically.html#d28390e65
PSP URLs will enable it to communicate between different machines and also between projects which may or may not be open.  The project variable will exist within the project.
Julian R.
Applications Engineer
(3,512 Views)
