Improving this loop
Is there an easy (fast) way of changing the value of elements within a 2-D array?
For instance, changing all num=9 to num=88 ?
I do have something that works, but I'd like to learn more "trade secrets"  😉
However, combining the suggestions in this string improved the sub-vi by a factor of 25-times faster!  Very significant indeed!!
Wow!!
RayR
Message 21 of 30
(2,251 Views)
I have nothing to add except to say that this is a mighty educational thread.  Great question and great answers!
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 22 of 30
(2,242 Views)
Ray,
if your array consists of numeric values, the replacement is very fast. There is (at least afaik) no ready-to-use function. So you got to implement it on your own.
Attached there are two screenshots for one possible solution which should run ok for you (even perharps not the fastest one. I benchmarked this one with 30k lines and 16 columns with under 100 ms.... but will be slower on slower machines. Please note that there should not be any typecasts within the loops, otherwise you will slow it down "accidently".
Norbert
Norbert
Expert: Geometry
Message 23 of 30
(2,233 Views)
If you need to replace multiple values, follow Norbert's suggestion but wire the value directly to the selector of the case structure. This way you can have multiple cases in one structure. The default case corresponds to Norbet's False case.
Tomi
Tomi Maila
Message 24 of 30
(2,223 Views)
Good point, Tomi, just was too narrow minded during answering that post 😉
Norbert
Norbert
Expert: Geometry
Message 25 of 30
(2,210 Views)
Hi Norbert,
Actually, I had already implemented a similar solution..
The elements of the array point to a case structure which populates the "string" array.  It's sufficiently fast.  I was curious if there was another trick that I was not aware of.
EDIT:  Just noticed that Tomi suggested the same <Thanks>
Once I convince them that the string array is no longer required, I will remove it.  😉
Thanks guys for all the help.  The overall progress on the older slower machine is in the magnitude of 100 times!!!  😮  - wow!!!! -
Test time dropped from 79 min to 6 min!!  I'd say that's "pretty good"..
THANKS!!  🙂
RayR
Message Edited by JoeLabView on 02-16-2007 12:03 PM
Message 26 of 30
(2,194 Views)
Thank you Ray for the entertainment!
This thread reminds of a quote from "The Silicon Valley Guy handbook" that ascribed the following characteristic to SVG's.
"One of my favorite pass times is Gang Applience re-wiring."
Ben
Message 27 of 30
(2,176 Views)
I'd suspect that the latest numeric substitution ideas would go a bit faster if you passed the array through Shift Registers and used Replace Array Subset to make changes rather than auto-indexing your output arrays.  Guess it depends how smart the LV compiler optimization is.  It'd take a fair bit of smarts for it to recognize the acceptability of reusing the same memory space in the auto-indexed output method.  With shift registers, it has no choice.
-Kevin P.
Message 28 of 30
(2,174 Views)
Perhaps we need a new loop tunnel type in LabVIEW that would be in-place auto-indexing. This tunnel would be a combination of shift register and auto-indexing tunnel. Like shift-register it would always be visible at both ends of the loop and it would operate in-place. Like auto-indexing tunnel it would auto-index elements from the array. It may not be a great leap for man kind but it would be a small step for LabVIEW performance tuners... 🙂
EDIT: I posted a product suggestion to NI.
Message Edited by Tomi M on 02-16-2007 07:28 PM
Tomi Maila
Message 29 of 30
(2,170 Views)
Try converting the 2D array into a spreadsheet string, then replacing all of the 9's in text with Search and Replace, then convert it back into a 2D array.
Message 30 of 30
(2,157 Views)
