‎02-04-2009 03:26 AM
Hi Ben,
The messages are as mentioned by Reiry
1. The URL does not exist or the WSDL is bad
2. Authentication is not correct
3. Proxy information is not correct
The URL is correct coz I can access it if I remove the authentication, and now in the newly introduced "Authentication info" page, if I put proxy/username-password it says "Bad WSDL" and if I don't put those values, then it gives the above error message with 3 points.
The problem is that nothing was changed when I could do it in the past, and nothing has changed after that success. That's why I don't know why it gives this error.
Thanks!
‎02-05-2009 10:11 AM
‎02-05-2009 11:21 AM
Hello!
Thank you for passing it to the R&D team. I hope to get atleast some idea about what is going on, either in my system or in LabVIEW.
‎02-06-2009 08:42 AM
I'm suffering form the same glitch.
Andrew is the CAR issue/ticket that you mentioned visible to NI customers? If so can I view the status of it?
A work around for this is to create your own .NET client.
If interested see thread:
http://forums.ni.com/ni/board/message?board.id=170&message.id=270831#M270831
Where some while ago I put an example on how to do that.
Cheers,
Maciej
‎02-06-2009 03:11 PM
Hi Maciej,
Customers can check the status of a CAR by calling in to 1-800-ASK-MYNI (1-800-275-6964) and referring to the CAR identification number.
Stephen S.
‎04-01-2009 12:53 PM
This number is incorrect? 1-800-ASK-MYNI (1-800-275-6964)
This connects me to some company that I believe they said was Red River Construction. I asked the phone rep to verify the number and she repeated it back to me.
I have the same question as the above posters I believe.
Can we get a straight answer on this from a rep?
Does LabVIEW support WCF web services (.svc extension)?
‎04-02-2009 04:16 AM
I've contacted my local NI representative so I can pass on what I have got form him about this.
The web-service import was done pre 3.0 .NET framework, and is not compliant with it. ( it was designed to work with ASP.NET )
The soonest modification possibility for the Web Service import is expected arround 2010 ( but that is tentative ).
I have used the svcutil.exe ( a microsoft WCF tool ). Created a .NET dll. And used it in my LV code. This works for me.
Hope this helps,
Maciej
‎04-02-2009 11:46 AM
The number is actually 1-866-275-6964 or 1-866-ASK-MYNI . Sorry for the misinformation.
‎07-27-2009 07:46 AM
Hi
i need a little help in using the svcutil.exe workaround for this. this is what i have so far:
This is all fine. The problem i cant seem to get past is that when i create a dll from the class library project there is no way to bundle up the config settings (endpoints, bindings etc) into the dll, so anything using this dll needs to have access to these config settings somwhow. In any VS2008 project i could just add them into the app.config / Web.Config. But i am a LV newbie and dont really undestand how i manage this in LV...or is there a way of compliing the setings into the dll that i haven't found?
Any help would be hugely appreciated.
jamie
‎07-28-2009 04:07 PM - edited ‎07-28-2009 04:15 PM
Jamiew.
Regarding .NET configuration files. They need to be in the same directory location as your application assembly.
The .NET configuration files are bundled with an application. In order to use a config file, you need an application in .NET, that usually means your *.exe file that contains the main method entry point.
I do not know why you would need a configuration file that goes with the client dll. The reason for that would be that the client .dll itself does not have an entry point.
Since the scvutil will generate a dll that doesn't have an entry point trying to use the configuration file here doesn't seem to be valid. Uless I'm missing something.
The configuraion file is aimed to configure your Web Service Server, not the client.
The svcutil is merely there to automatically generate the code for a .dll file that will be a part of your client application to your webservice an enable you to consume it.
In this thread I've put an example on how to consume a WCF web service via the scvutil generated client library please take a look at it maybe this will help you.
http://forums.ni.com/ni/board/message?board.id=170&message.id=420547#M420547
Cheers,
Maciej
PS. Man I edited this a lot of times ... ;] It's late.
