Implicit cast on Variant to Data
I'm seeing an implicit type cast at the type-terminal of variant to data and I'm losing the type definition on that wire. Never seen such behaviour before; vtd usually accepts any type definition. Unfortunately I can't share the code. The TypeDef contains clusters (with booleans, boolean arrays, single, integers) and a variant.
Has anyone seen this before? I'd use TypeCast as a workaround, but it doesn't accept clusters (broken wire).
(LabVIEW 2018 32 bits on Windows 10)
Although I've been 10+ years long fan of LabVIEW, I started to discourage engineers to start new projects in a SaaS language. NI must first regain trust within its community.
(1,942 Views)
Accepted by topic author benjamin-hinrichs
I found the culprit to be a fixed size boolean array. Also coerce to type manages to cast it to a typedef.
Sample code attached.
(1,888 Views)
You can replace the data indicator with the type definition. You'll get a coercion dot.
(1,866 Views)
