Image processing
Thank you Andrey. Is there other option to done that without Vision Development Module ?!
Message 11 of 17
(896 Views)
Hi Omar,
Yes.
Load the JPG image as shown above and analyse the pixmap data on your own.
(You need to re-implement all those IMAQ routines with your own LabVIEW code…)
Message 12 of 17
(887 Views)
Yes, sure, but here you will need to invest more time. You must be able to open the image as a 2D array of pixels, then you can do almost everything — get the line profile along the marks (it's better to do this not at a single line, but average multiple pixels in the opposite direction — this will give you better signal to noise ratio and will remove small dust particles, etc.). Then you will need some kind of edge detector (Sobel/Canny) or peak/valley detector to detect the marks and count them. You don't need to implement Vision Development Functions 1:1 (and you can't, because details of the internal processing are not always known). If you don't have experience with image processing, I would recommend to read some books first (for example, 'Digital Image Processing' by Rafael Gonzalez and Richard Woods).
Message 13 of 17
(859 Views)
Here is one way without using IMAQ:
George Zou
Message 14 of 17
(828 Views)
Thanks Zou, but it didn't count the lines?!
Message 15 of 17
(804 Views)
You should simply go through waveform chart and count how many times you changed from 0 to 1.
Something like that:
Message 16 of 17
(797 Views)
Thanks Andrey, I got that, sorry but it's my first time use LV with images.
Message 17 of 17
(785 Views)
