Image processing
Hello gents, I want to ask question if someone can help me regarding the idea of calculating the number of lines on picture using LV. example of that is the attached image, what I need is developing a code to calculate 21 which is the number of lines on a picture.
Message 1 of 17
(2,131 Views)
If you have NI IMAQ, take a look the Line Profile example.
George Zou
Message 2 of 17
(2,122 Views)
Thanks George, I have NI IMAQ but I couldn't find line profile example.
Message 3 of 17
(2,115 Views)
LabVIEW20xx\examples\Vision\2. Functions\Analysis\LineProfile Example.vi
If you can't find this example, you probably don't have the Vision Development Module.
George Zou
Message 4 of 17
(2,110 Views)
Like this:
Message 5 of 17
(2,081 Views)
Message 6 of 17
(2,048 Views)
@Omar-Abdelhameed wrote:
Thanks Paul. I did yours and resulting wrong.
It seems to be you need something like that, isn't?
By the way, the contrast of first mark is too low, you need better and uniform lighting.
What is your expected result?
Message 7 of 17
(2,028 Views)
Thanks Andrey, yes this is what I need and then I can use the result 20 to specific calculations. can you please share how to get that ?
Message 8 of 17
(2,009 Views)
If you have fully installed Vision Development Module, then you must have also Vision Assistant which is bundled into installation (32 or 64 bit, I will recommend to install same bitness as used LabVIEW).
This is great tool to prototype and modelling your processing, and once you satisfied with result, you can export complete chain into LabVIEW VI and continue development, modification and fine tuning in LabVIEW, that is:
Message 9 of 17
(1,999 Views)
Sorry.  I misunderstood what you were asking.
Message 10 of 17
(1,964 Views)
