If, Or, Else, Then statement
Hello again,
I'm trying to make a statement for the following:
If X = 01 or 13 or 18 or 23 or 24 or 30, then range = Y
If X = 02 then range = Y
If X = 03 or 20 or 21 or 25 or 29 then range = Y
Else range = Y
I'm going to be using it in a state in a state machine. It will allow the software to automatically tell a pressure calibrator what range to be in.
Thanks everyone
(3,998 Views)
You did not actually ask a question so we are not  sure what you want.
Look at a case structure.  If X is an integer data type, wire it directly to the selector terminal.
Lynn
(3,986 Views)
Accepted by buickgn
Hi buick,
when you always have "range = y" then you don't need any case structure at all Smiley Wink
If you insist on separating those cases: use a case structure and wire your case selector integer to its selector input. Read the help for the case structure...
(3,984 Views)
Sorry. When a user inputs a part number, the application parses the string and returns numbers 01-30. I want to take this number and use it in the if, or, else, then statement so I can input the correct range to a pressure calibrator.
(3,983 Views)
Hi buick,
use a case structure.
No IF, THEN, ELSE, ELSEIF, ENDIF, FI needed...
(3,980 Views)
(3,978 Views)
I'm mad I didn't think of that.... Coffee time!!
Thanks everyone!
(3,974 Views)
