Icon editor text squinching when add some glyphs
In LV2015sp1 icon editor, I get problems where the text compresses and tries to fit into the vertical space of one of the glyphs in the image. Example attached.
Often happens when adding a VI to a lvlib and applying the lvlib icon, or when modifying an icon on a vi that's been created as Save A Copy.
Happens fairly often, and is frustrating to work around (basically I either remove the glyph or hand-redraw the glyphs and the text behaves normally). How to fix or prevent?
(3,677 Views)
I reported this and posted it on the LabVIEW Idea Exchange here.  I was told that this had been fixed, verified that it seemed to be fixed, but then found it wasn't fixed.  I did not manage to follow up at NI Week 2016, but hope to do so at NI Week 2017.
(3,638 Views)
Nope, not fixed. And your Idea was closed, so I can't upvote it. I haven't verified that LV2016 has the same problem.
Did you ever find a workaround? Deleting the layer with the glyph and redrawing the glyph on another old layer (can't be a new layer) is the only thing that works for me consistently.
(3,629 Views)
Accepted by lgc102
Well, I did find a work-around.  What I was trying to do was to create an Icon Template for an Icon that I saw Aristos Queue use -- the Icon looked like a While Loop, and was mnemonic for a VI that ran (as a loop) asynchronously.  Here's a picture of one of my "Loop" VIs (it displays Video images), the Template I wanted to use, and the "workaround" Template I ended up using.Loop Template.png
You'll notice that the template has a double-thick rounded border (like a While Loop), with arrow.  If I made a template that looked like the middle one, the text tried to insert itself between the bottom two lines (bad!).  So I made a one-line-on-the-bottom template (last example), and when I select it, I draw in the additional bottom line (it appears as a Layer), and all is well.
The "trick" is to avoid double lines on the bottom (they are fine on the top).  You also want to do the minimum amount of "hand-fixing" (I only needed to draw one obvious line).
(3,620 Views)
For work around, have you tried removing the template?
or use a simple 32x32 square frame?
George Zou
(3,612 Views)
