Icon Labview
What is this icon in labview?
(2,317 Views)
Enable context help (ctrl+H) and hover over it with your mouse.
Bill
CLD
(Mid-Level minion.)
(2,281 Views)
Or right click, Visible Items>Label.
Or drag & drop the VI in a string or path constant (or a path control or a free label)...
Or if it's a VI, double click to open it. See VI Properties>General to get it's full path.
(2,276 Views)
Where did you find it? Do you have code that includes it or you want to recreate a VI from a picture seen in a book, article, or web page. If you found this on a diagram picture, give us the link. If you have the VI, do what was suggested. You can even double-click it and look at the code. Maybe there are diagram comments describing some functionality. You could even attach it here.
My guess is that this is not a VI shipping with LabVIEW or from any well-known module or toolkit. From the limited information, the upper right input wire has the wrong representation.
(2,265 Views)
Sort of correct.  It is not a VI shipping with LabVIEW, it is an XNode shipping with LabVIEW.  I use this one quite a lot, it is called GetValueByPointer.xnode
You can find it here
<vi.lib>\Utility\importsl\GetValueByPointer
Just remember if you are using 'Select a VI...' from the right-click menu to change the filter to 'All Files' to see it.
(2,202 Views)
