install php
Hi all
my measurements are stored in a DB hosted on cRio controller and i need to create an API to access them. That is where PHP comes in
As far as i know i cannot use the NI webservices since PHP is not available so i installed apache using a different port than 80.
The problem is i cannot make PHP work .... Without it the server works fine
i install  php and  php-fpm , restart apache and then the php files are not parsed and appear as plain text
Does anyone have an idea ??
(1,679 Views)
It sounds like you did not configure Apache to link php files to the fastCGI process manager (php-fpm).  Since this is Linux Web Server 101 stuff, it has been done countless times before, just google 'php fpm apache' and you will get numerous how-to guides to updating the apache .conf files.
(1,612 Views)
