IF [then] ELSE [void]
Hello people. I need help figuring this problem out.
The program's input is an array of strings. and is meant to do the following:
for each element in the array, checks if the string begins with "$GPRMC"
if this is true, then process the data and spit a value calculated from the string.
else, void (i.e.: not to generate an output value because it spoils the calculations)
i've attached a simplified version of the actual VI. [I'm running on 8.2]
Message 1 of 12
(4,714 Views)
I added what I would do to the top of your orginal vi.
Tim
GHSP
Message 2 of 12
(4,705 Views)
Hi nihil,
 Check whether it will satisy your requirement....
Thanks and regards,
srikrishnaNF
Srikrishna
Message 3 of 12
(4,703 Views)
thank you guys!
can't see any of them (i have labview 8.2)
maybe an image?
Mensaje editado por Nihil
Message 4 of 12
(4,702 Views)
  I think i uploaded 8.5 version.here is the 8.2 version.
Thanks and regards,
srikrishnaNF
Srikrishna
Message 5 of 12
(4,697 Views)
This is the way I would ultimately do it. A little more simple than your orginal idea.
Tim
GHSP
Message 6 of 12
(4,693 Views)
Accepted by Nihil
Here is an 8.0 version.
Tim
GHSP
Message 7 of 12
(4,690 Views)
Thank you!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
:smileyvery-happy::smileyvery-happy:
Message 8 of 12
(4,681 Views)
You are welcome. Did you understand what I did? I would like to think that you are learning from what I have shown you.
Tim
GHSP
Message 9 of 12
(4,676 Views)
yes, instead of modifying the original array you created a new one. and to that new array inserted the elements in the old one that matter.
don't know if this is what you wanted me to see...?
Message 10 of 12
(4,660 Views)
