‎03-06-2011 04:40 PM
Is there some toolkit or similar, that will allow me to write code for PIC micro (10F or 12F)?
‎03-06-2011
04:52 PM
- last edited on
‎06-04-2024
10:30 AM
by
Content Cleaner
The closest thing is te expensive LabVIEW Embedded.
‎03-07-2011 02:31 PM
Good day!
Dennis is correct, the closest would be using LabView Embedded. Your best bet, as an alternative to that software, is to just create serial communication between LabView and your PIC microcontroller, if that will work for your application. Hope this helps!
Joe S.
‎03-07-2011 02:41 PM
Serial communication, you mean, only to transfer data, not actually writing an embedded code, right?
If I use embedded module, can it work with 8bit microcontrollers, like pic18f, pic12f.... ?
‎03-07-2011 02:50 PM
Actually, I believe the LabView embedded only works with specific processors and will not work with 8-bit PICs. Yes, serial communication to transfer data rather than writing code to run on the controller.
Joe S.
‎03-07-2011 03:00 PM
‎03-08-2011 04:39 AM
No the LabVIEW embedded toolkit only supports specific development boards out of the box. You can add other boards to that list if they use same CPU architecture. Adapting it to a new CPU architecture and/or toolchain is a LOT more work. And trying to do that for non 32 Bit CPUs will be in vain at best , meaning it's probably not possible at all, and definitely not worth the effort.
