question about sample rate and PXI 5122
Hello! i am new at using labview and pxi cards. i am trying to sample a signal from an analog gennerator with pxi-5122 so afterwards i can process the samples and extract the processed samples to an oscilloscope through pxi-5421. i tried to use the labview examples for pxi-5122 for sampling and processing( more precisely the example "digital filtering"). They are working perfectly for high sample rates (some MHzs), but when i try to sample low frequency signals (for example 20kHz) and use sample rate according to Nyquist criterion, the acquired samples dont reconstruct the initial signal at all. if you have experienced similar problems, how can i sample low frequency signals with sample rates according to Nyquist criterion?
(2,287 Views)
Nyquist criterion says: "sampling freq. should be at least twice the max. feq. component in the signal". For better reconstruction you should keep the sampling rate to some 8-10 times of max freq. component in the signal.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(2,283 Views)
