I need a way to store ('latch') a measured value in memory
I need a way to store a measured value into a variable when I press a button (using an event structure). This stored value needs to be available like a local variable for the duration of the running of my program. Whenever I click the button, a new measurement is taken and the stored value is updated; but otherwise it is 'latched' between updates.
Dave
(3,517 Views)
Hi Dave,
Take a look at this Nugget on Action Engines.
Use a "write" method in the event case and a "read" method everywhere else.
Have fun!
Ben
(3,511 Views)
Instead of 'latching' a value into a 'local variable', how about storing an array of the values in a shift register?
If the user clicks on the 'Obtain Value' button, a value will be appended onto the already existing array.
If the user does not click in N seconds, a timeout will occur in the event case, and no value will be appended to the array.
Message Edited by Cory K on 03-09-2009 08:57 AM
Cory K
(3,509 Views)
Thanks. Nice idea. I like the simplicity of this.
I have to say I'm pretty confused about action engines at the moment (are they a 'thing'/VI one uses, or more of concept in programming?) so perhaps will have to come to them another day!
Dave
(3,482 Views)
Dave
They are something you code then use in your program. Since you code them yourself, they allow almost endless potential to be customized just the way you like. To start your code would just use a read and a write. Latter on you may wnat to add another method like (Compare this value with Latched".
Ben
(3,479 Views)
Cory, one question on this: why the need for a timeout? Dave
(3,445 Views)
