I have a problem with clearing previous results from indicators and LEDs
I'm working on building a proper VI for my project but there is a problem .. The project here is to define the error occurrence and type of errors to decide which  actions are needed to protect the circuit  .This is not a problem here ..
The problem is when I run the VI for first time .. Everything is good and I got what I need   ..But when I run it after that  .. The new results come out with the results from the first run .. So my problem is with clearing  previous results from indicators and LEDs
Hope my question is clear and not confusing
Message 1 of 9
(3,576 Views)
Accepted by Amnaa
Well, show us some code instead. How are you calling the VI?
Have you tried the option: "VI properties...execution...clear indicators when called?"
Message 2 of 9
(3,575 Views)
OK Sir .. Thanks a lot  .. The problem is solved now .. Thanks to YouSmiley Wink
Message 3 of 9
(3,573 Views)
Did you solve it on your own? If not, you should mark the most helpful post as solution.
(Your post above does not contain a solution at all, so why did you mark it as such?)
 Thanks!
Message 4 of 9
(3,561 Views)
I tried your suggestion >>> the option: " file ....VI properties...execution...clear indicators when called"
I marked my post by mistake (accidentally) >>> so >> Sorry .. Your suggestion solved my problem ..
Message 5 of 9
(3,553 Views)
You can unmark the solution from the options menu in the upper right corner of the post.
Message 6 of 9
(3,548 Views)
Well Okey >> I feel stupid right now Smiley Frustrated.. Sorry I just registered yesterday Smiley Embarassedso sorry again ..
Message 7 of 9
(3,543 Views)
No problem! Welcome to the forum. 🙂
The marked solution feature is useful for other new users in the future that have the same problem. Thanks!
Message 8 of 9
(3,541 Views)
You are So welcome Robot Very Happy
Message 9 of 9
(3,539 Views)
