I am trying to create a single exe. The build creates directories NI_HTML,NI_report,NI_Standard Report
The build keeps telling me that I have 3 sets of files the same name from NI report
The VI's are creating 3 times the files I require
It also tells me to select renaming files
Can any body tell me how you do that
(3,298 Views)
This Knowledge Base may be helpful - http://digital.ni.com/public.nsf/allkb/47272B69E2C167DB862574AC006A258B
George M
(3,290 Views)
Accepted by Thales
This is a (current?) limitation of the executable structure. Since you use the report generation (or any auto-dispatching class) LabVIEW needs to distribute these files outside of the executable, not something to worry about, however you need to make sure these directories stay with the executable.
See here for a KB article
Ton
My LabVIEW Ideas
(3,289 Views)
