Odd timings while using the time loop
I am having problems with the "Timed Loop". Even on a simple vi I cannot get the timings to be consistant.
I opened up a new vi and put a time loop with a Read From Feild point connected to a time stamp. The loop is set to 5000ms (5sec). The time stamp however sometimes does not change or it will, but not in intervels of 5 seconds.
Chaz
(3,119 Views)
Hi Chaz,
on which OS or platform is your vi running? Is it real time?
Mike
(3,116 Views)
Windows Vista Home Premium (SP1) and LabVIEW 8.5.1. Yes using a cFP-2120 with cFP-TC-120 & cFP-CB-3
(3,112 Views)
Hi Chaz,
where is the vi running, on your Windows System or on your cFP? You need a real time system to get real time values.
Mike
(3,098 Views)
Hi Mike,
Thanks for quick responce. It is running on the Windows system. I am fairly new to this... 😞
If it helps ~ Currently got the cFP wired via ethernet to the pc, using static ip.
(3,095 Views)
