How to use a thermal camera in Labview (Optris PI 640)
Thank you for your reply.
I did not quite understand those steps.
Can you explain me more? And if you can posted screenshot I will be grateful.
Thank you in advance
Message 11 of 34
(6,026 Views)
Accepted by gookman
Sure thing bud. Here is a screen shot regarding step one.
This is the program source folder for the Optris PI Connect program. (C:\Program Files (x86)\MICRO-EPSILON Messtechnik GmbH u Co KG\TIM Connect). I downloaded the program from a company called Micro Epsilon, but I think it should be on the CD that comes with it. Notice how I made that folder named "Imager.exe"
Now, within the Imager.exe folder, cut and paste all these files in there. These were originally on the source folder.
Now try running one of the example VI's that I included in my first post such as "IPC_GettingStarted-0.vi"
Message 12 of 34
(6,013 Views)
Thank you so much
Message 13 of 34
(6,003 Views)
I tested your solution, but the problem that NI MAX does not recognize my camera. You had the same problem? You have an idea how to solve this?
Thank you in advance.
Message 14 of 34
(5,896 Views)
I actually never checked if NI Max recognized my camera (I don't think it did), but What's important is that Optris PI connect recognizes the camera. The example VI's simply transfer the data from Optris PI connect to the VI
Message 15 of 34
(5,891 Views)
When the camera is not connectable to NI MAX, the VI program does not recognize the camera and it displays an error at the input (VISA_open). So if the camera is not detectable on NI MAX we can not perform the simulation.
Message 16 of 34
(5,886 Views)
Hi Gookman,
I also am stuck trying to program an Optris PI 450 camera in LabView. I tried to contact Optris directly, but they never answered.
I downloaded the first 4 files from your original post, but they ask me for the SubVIs. Would you possibly be able to upload those VIs or direct me to a link to find them?
Thanks!
Message 17 of 34
(5,736 Views)
I have the same problem, and my boss contacted the supplier and we had an answer, indeed you can not drive Optris PI 450 under labview, the provider does not give access. Only the PI 640 which is usable under labview.
Message 18 of 34
(5,717 Views)
Thank you for the response!
That is a shame to hear, I guess I will have to look at alternatives then.
Message 19 of 34
(5,709 Views)
Disregard this message
Message 20 of 34
(5,697 Views)
