How to stop my 1553 Remote terminal application from locking up the Front Panel when the Bus Controller application is causing msgs traffic over the 1553 bus. This simulation uses WIN98SE with excalibur ISA cards.
This simulation has several transmit and receive messages. The fastest message refresh rate is set to 50Hz (20 ms).
(2,751 Views)
Can you provide some more information about what hardware and software you are using? What is your application? Thanks!
JenK
(2,729 Views)
