How to speed Excel data dump?
It takes a long time to dump data into Excel (2003) spread sheet during data dump (test report). I need to speed up the process.
1)  How can I disable the update property of Excel (that may help speed the dumping data process...).
2)  I would like to turn off viewing of the  Excel spreadsheet (but dupming data in the background), that may help or not? How can I do that, and which VIs from the library can I use, any sample code?
I am using LabVIEW version 7.1 on XP.
Thanks for your help.
LVLV
Message 1 of 8
(4,139 Views)
I've attached a vi showing how to turn off viewing of Excel (that is, make it invisible). Wire the appropriate control to False, for not visible.
Message 2 of 8
(4,115 Views)
To answer the first question, access the "EnableCalculation" property of the worksheet object.
Message 3 of 8
(4,090 Views)
To answer the first question, set the ScreenUpdating property of the Application object to false.
Michael Munroe, CLD, CTD, MCP
Automate 1M+ VI Search, Sort and Edit operations with Property Inspector 5.1, now with a new Interactive Window Manager!
Now supports full project automation using one-click custom macros or CLI.
Message 4 of 8
(4,025 Views)
LVLV,
Could you tell us the improvement, if any, obtained after these optimisations ?
Chilly Charly    (aka CC)
Message 5 of 8
(4,018 Views)
Thank you all, it worked great.....
-LVLV
Message 6 of 8
(3,995 Views)
Hello everybody,
I've the same problem using LabWindows.
I don't know how to disable the sreenupdating property.
Can you help me please ?
Mathieu
Message 7 of 8
(3,668 Views)
Well, in terms of Excel, it's the same property/method. In terms of using ActiveX with LabWindows, you're better off asking this question in the LabWindows forum. This is the LabVIEW forum. LabVIEW is the graphical programming language.
Message 8 of 8
(3,645 Views)
