How to set colors in multicolumn listbox's cells?
Is there a possibility to set colors of multicolumn listbox's cell's texts programmatically?
Message 1 of 24
(23,453 Views)
there is a property that changes the active cell color.
but I don't know about all of them
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 2 of 24
(23,446 Views)
Yes.
First set the active cell to the cell you want to manipulate (read the help on this terminal, -2,-2 selects the whole list box ...)
Then use
CellBG to set the background color of the cell
or
CellFontColor to set the font of the text.
Have fun!
Ben
Message 3 of 24
(23,419 Views)
Here's an example of how to find a certain cell value and color it. Remember to initialize all cells as white before doing this, or the cells that get colored will stay that way even when the data changes.
Richard
Message 4 of 24
(23,412 Views)
Thank you very much for help. I tried and it worked.
Taron
Message 5 of 24
(23,371 Views)
How do you initialize the color of the cells as white?
Message 6 of 24
(23,047 Views)
Read what I wrote in post # 3 and use white as the color.
Ben
Message 7 of 24
(23,041 Views)
For everyone's edification...
Changing the background color of an individual cell is extremely slow.  It takes me about 15 seconds to set the background color of each cell in a particular column in a 1000x6 multicolumn listbox. Changing the entire row to the specified color is orders of magnitude faster, even though the same number of calls is being made to the property nodes.  Changing the text color is about twice as fast as changing the background color, but still unacceptably slow.  And yes, panel updates are being deferred. This problem exists in LV2009 through 2010SP1. A CAR (#188518) has been filed. Unfortunately, this severely impacts the GUI I had intended on using for a new application.
Message 8 of 24
(22,720 Views)
How about
defer, hide the list box, do the update, show the list box, undefer?
Ben
Message 9 of 24
(22,716 Views)
Just tried it - that makes no difference in performance, not that I would expect it to.  If panel updates are being deferred, I don't see what benefit hiding the control would be?
Message 10 of 24
(22,706 Views)
